Data granularity
  • churari
    • Feb 2012
    Data granularity
    I am investigating Zabbix as a possible alternative to Cacti. I would like to learn more about the configuration of the data granularity and aggregation. Is this something you have full control over or is it set by the system to automatically "roll up" the data at set intervals.
    I am specifically looking to keep 1 minute granularity for a long period of time 6 - 12 months. I understand there will be database size issues.
    Is this in your control? Also, I looked through the manual but could find the information regarding this. If it is documented some place I will happily do the reading.
  • ahowell
    • Jan 2011
    • 66
    Read the manual in the item configuration section, particularly history and trends settings.
    The installation section of the manual also has information about database size based on history ands trends settings.
