This is a guide for people that normally never work with mysql stuff.
My main problem is that my zabbix InnoDB database get corrupted now and then (sometimes every month , sometimes less, Running under centos , vmware)
(problem started after a few years of collecting data)
I just wanted to share how to repaired my InnoDB and got my Zabbix up and running again.
(Iam using Centos and webmin installed)
1. service zabbix_server stop
2. Edit /etc/my.cnf
Add this line to the config: innodb_force_recovery = 4
3. service mysqld restart
4. If you don't have webmin installed you can download it from www.webmin.com or use any other mysql tool.
Backup the databse called zabbix
Example: Successfully backed up 236040666 bytes from database zabbix to file /root/zabbix.sql
!!!Make sure you made a full backup and know where you placed it!!!
5. Edit /etc/my.cnf
Remove the line by adding a # infront of it. #innodb_force_recovery = 4
6. service mysqld restart
7. Enter webmin or any other mysqltool and DROP zabbix database (will remove all data)
8. Create a new database and name it zabbix
9. Enter the new databse named zabbix and perform the command: execute sql file and select the backup you made in step 4 (/root/zabbix.sql)
This step will take some time if you have lots of data. (2-15 mins)
10. service zabbix_server start
11. done, errors gone, data base is fixed, atleast for me!
Good luck!
2. Edit /etc/my.cnf
5. Edit /etc/my.cnf
Good luck!
