auto group/template with EC2
  • thecord
    • Feb 2012
    • 10
    I am wondering if there's anyway I can set something on the Zabbix agent, probably in the conf file, that when a machine fires up will have the Zabbix Server auto assign a group and template for monitoring? This seems to me the last mile for Zabbix, full automation. Is this possible?
  • eskytthe
    • May 2011
    • 363
    Use auto registration or discovery. Auto registration is more limited then discovery.
    http://www.zabbix.com/wiki/howto/config/autoregister
    /Erik
    • thecord
      • Feb 2012
      • 10
      I have been using that, but I am not able to see the functionality where I can auto assign a machine into a particular template/group. I can see where I can assign all autodiscovered/registered machines into a template, but I want to use different templates for different groups of machines.
      • thecord
        • Feb 2012
        • 10
        clarification
        To clarify, I guess I'm wondering how a machine running Zabbix Agent can, auto register, and based on some set of characteristics (hostname, configuration line in the zabbix-agent.conf file, etc) have the Zabbix server assign the appropriate template to be used for monitoring and put the new machine in the appropriate group.
        • thecord
          • Feb 2012
          • 10
          May have answered my own question...
          Under Configurations -> Actions then selecting Auto Registration as suggested above, which I was using before. However I didn't notice the conditions tab which can be a hostname with wildcard and potentially regex, not sure about the latter though.
          • eskytthe
            • May 2011
            • 363
            I suppose you also have seen that you have even more options with discovery...
            (Auto delete hosts etc.)
            /Erik
            • thecord
              • Feb 2012
              • 10
              Discovery seems very interesting, however how does one do this in the cloud, specifically ec2. I obviously cannot search through a range of ips. Can I do discovery through launching a zabbix agent then registering? Second, is there any authentication I can set so foreign hosts can't register?
              • eskytthe
                • May 2011
                • 363
                I have no experience with cloud and discovery.
                Just an idea: You could make you own extention to the auto registration, if it do not fit your needs. Eg. could do som api or zapcat manipulation after the auto reg. - move hosts to other groups etc
                You can find api/zapcat/php/bach/perl interfaces etc. in the forum. One exsample:
                As I see it discovery is started from zabbix server. Auto reg. is started from agent side.
                Auth: I only know of the action operations and condition you specify (you may not call this auth.)
                Hope this help.
                Br
                Erik
                • thecord
                  • Feb 2012
                  • 10
                  Definitely helps. Thank you.
                  I can do nearly everything I want except auto delete servers after auto-reg. That's all I have left to do, if there's a good way, I'd love to know it.
