Newbie here :-)
I am testing Zabbix 1.8.10 for internal monitoring of multiple servers and applications, including lots of internal Admin web pages for those applications.
Configuring a Web Scenario is simple and easy. I just don't need the "Download speed for scenario" check that is added automatically as "hidden" step and behind the scenes. Is this check mandatory or it could be skipped / disabled somehow?
All my Web Scenario checks will be performed through the internal 1Gbps LAN and I just don't need to collect and store uneeded data...
I've checked the documentation for Zabbix 1.8: Manual -> "9. Web Monitoring" and it contains the following statement:
"As soon as a scenario is created, Zabbix automatically adds the following items for monitoring and links them to the selected application. Actual scenario name will be used instead of “Scenario”."
That's OK, but I can't see any Items linked to my custom Application, so I guess they are some "hidden" Items...
Any ideas and/or hints how can I disable / skip this "Download speed" check would be greatly appreciated :-)
