User permissions for UserParameter
  • NotTheFace
    • Feb 2012
    • 10
    I have a custom UserParameter which needs to be run as root. Is there any way to change the user that check runs as, for only that check. I'd rather not have the agent itself run as root. Or is this something best fixed at the OS level.
    Thanks in advance,
  • JBo
    • Jan 2011
    • 310
    You can use sudo to run a command as root.
    In zabbix_agentd.conf, replace:
    UserParameter=my_parameter, my_command
    with:
    UserParameter=my_parameter, sudo my_command
    In /etc/sudoers, add:
    zabbix  ALL=NOPASSWD: my_command
    Regards,
    JBo
    • NotTheFace
      • Feb 2012
      • 10
      Thanks, but annoyingly the Solaris machine doesn't have sudo installed. I guess then that the correct fix is something at the OS level rather than internal of Zabbix.
