Triggers not emailing
  • bundaburg1
    • Feb 2012
    Hi All,
    I have an issue where triggers are not being emailed to users. It only happens on certain hosts and triggers.
    For example, currently trigger "CPU Utilisation too high on xyz" is meant to be emailed to user "A" and "B". The trigger has been triggered, and it appears on the dashboard, but in the actions row, there is a "-", no email sent.
    But ff I go into that host and clone that exact trigger with a different name, it automatically appears on the dashboard and sends the emails to the correct users.
    This has been hapenning more and more recently, and with over 12000 triggers defined, I am finding that I have to do the cloning workaround quite often.
    Thanks for your help!
  • Alex_SYB
    • Feb 2012
    • 133
    Hi
    I might have the same problem I have the VM appliance of zabbix.
    And I can't get any emails to be sent at all.
    I have configure email media, I have user it is meant for.
    and I have an action setup, basically, my understanding is if any trigger is triggered if the host group <> zabbix server then send mail... but nothing
    I see on the dashboard lots of red and stuff
    but in admin / notifications nothing ..
    • frankymryao
      • Oct 2011
      • 52
      This similar problems about no actions with triggers were confused me for a long time. And now we are all okay with them.
      For my experience:
      1. check the action you defined is correct.
      2. is the zabbix overload? It is occurred to us that trigger is showed on dashboard but no action produced(random incidents). After our patch zabbix code to solve the high concurrency, all action-with-trigger works well. You can check if your zabbix performance is Okay.
      3. Adminitration-Audit, it can review your actions
      • Alex_SYB
        • Feb 2012
        • 133
        For my experience:
        1. i believe so but being a newbie I am unsure ! I created a new trigger and used all the defaults, added in a action operations - which is send email
        2. na don't think so... about 20 devices its talking to
        14:47:04 up 12 days, 2:06, 1 user, load average: 0.04, 0.18, 0.19
        USER TTY LOGIN@ IDLE JCPU PCPU WHAT
        root pts/0 14:47 0.00s 0.04s 0.00s w
        3. don't see anything in here for now except login for guest failed...
        • Jun.Liu
          • Apr 2007
          • 91
          I encountered same problem with zabbix 1.8.10:
          "the trigger appears on the dashboard, but in the actions row, there is a "-".
          Actually I had made it working before with 1.8.6. and now I'm setting up a new server with 1.8.10.
          Any hint?
          • Jun.Liu
            • Apr 2007
            • 91
            just found the answer for my problem: the user which send the email/alarm must at least have the 'read' permission on the hosts which generate the triggers!
            please check if you have same situation!
            • frankymryao
              • Oct 2011
              • 52
              great experience. for that alex has mentioned 'don't see anything in here for now except login for guest failed...', I think alex should check the permission.
              • Alex_SYB
                • Feb 2012
                • 133
                Hi
                Thanks for the replies sorry for the long delay.
                The user has admin right. as in the destination email.
                I set up a new action, that send to a trigger group, that has a user which has admin rights !
                I should point out I like testing things as I type. so i check the group and it didn't have read permissions ! so now I have set it to all read
                but i would have thought I would have seen something in the notifications page -
                as for the login failed. that was the zabbix web monitoring checking itself with a guest login that failed !
                • Alex_SYB
                  • Feb 2012
                  • 133
                  Thank you, read permission did it. I am not being bombarded with emails
