In my Zabbix installation (1.8.10) I link a zabbix trapper item to every host called snmptraps just to be able to receive SNMP traps for each host. Now that I'm dealing with maps, I found that, if no trap is received for a given host, this host is displayed as if it has a problem. If I disable the snmptraps item for that host, it is displayed as ok.
Is there a way to exclude an item from the map so that it can display the host as healthy even if no data is stored for that item?
Thanks,
Oct
Thanks,
Oct
