Edit an Item (linked to Template)
  • chandra
    • Feb 2012
    Hi Guys,
    I would like to edit an Item "Free disk space on C:", this Item is linked to template windows.
    when I try to edit the trigger of this item, I don't have option to change the values, and even i can't able to remove this item, its coming up with the error can't delete the template item.
    I don't want to unlink the template for this host, because there are some other items I am using.
    Is there any other options to change the trigger value
    {host:vfs.fs.size[c:,free].avg(2400)}<1048576000 & {host:vfs.fs.size[c:,free].last(0)}<1048576000
    to
    {host:vfs.fs.size[c:,free].last(0)}<21474836480
    I am using Item Key: vfs.fs.size[c:,free]
    can we have any other key to calculate free space for the Item
    Regards,
    Chan
  • ahowell
    • Jan 2011
    • 66
    Originally posted by chandra
    Hi Guys,
    to
    Regards,
    Chan
    A better way to do this is to use a user macro as the trigger value. Set a default or it in the template and then change it on hosts where you won't it to be something different.
