I have set up several simple checks for icmpping but i am always getting a 0 result when fping gives results back
I have fping installed and this can be accesses by the zabbix user
-rws--x---. 1 root zabbix 27824 May 19 2010 /usr/sbin/fping
[root@monitor tmp]# su zabbix -c "fping -c 3 -p 100 -b 56 -t 150 monitor.rikrobson.co.uk"
monitor.rikrobson.co.uk : [0], 84 bytes, 7.19 ms (7.19 avg, 0% loss)
monitor.rikrobson.co.uk : [1], 84 bytes, 5.08 ms (6.13 avg, 0% loss)
monitor.rikrobson.co.uk : [2], 84 bytes, 5.13 ms (5.80 avg, 0% loss)
monitor.rikrobson.co.uk : xmt/rcv/%loss = 3/3/0%, min/avg/max = 5.08/5.80/7.19
[root@monitor tmp]#
as you can see this has the correct permissions.
tmp dir is also accessible by zabbix as you would expect.
I have a test server set up the same and this just works fine, but i cannot find the problem as they look the same
I have also tried icmppingsec and icmppingloss, Both return 0.
This indicates that the problem may be with zabbix communicating with fping
Does anyone have ant suggestions as to the cause of this problem?
[root@monitor tmp]#
ing_t:s0 tcontext=unconfined_u
bject_r:initrc_tmp_t:s0 tclass=file
