Need HELP : Proof of concept, Monitoring Proliant DL360/G6 local HD / VmWare ESXi5
  • vg30
    • Feb 2012
    Hello everyone...
    Here's the goal of the P.O.C....
    Monitoring the status of the local Proliant DL360/G6 hard disk, while this system runs VmWare ESXi5.
    It's important because the Proliant are booting on the local disk(s), that are either RAID 0 or RAID 5, and monitoring the status of the LOCAL disks is important.
    The status of the Virtual Machines is not a problem, as they're already monitored under Zabbix.
    The proliant have been patched with the latest version of HP Service Pack for Proliant (SPP), and now have iLO2 (Firmware 2.07, 08/17/2011)
    SSH is activated on iLO, and on the ESXi5 kernel
    ESXi Shell is activated on the ESXi host
    ESXi has been downloaded directly from HP, software version is HP-ESXi-5.0.0-20110904001 (STANDARD)
    Now, I would like to be able to monitor
    -As much as possible about the above ESXi host.
    -The local hard disks on the ESXi host (Proliant DL360/G6)
    Here's what I found.
    I can "speak" with the Proliant iLO2 using
    ssh admin@IP_of_iLO show -all /system1/drives
    <enter password>
    Then I can see "more or less" the status of the drives in the bay
    If drive status=Ok , then it means all is OK
    If drive status=Spun Down , then it means that one of the HD of the RAID5 has been removed, but I can't see which drive has been removed,at the same time the ESXi is still working.
    If drive status=Rebuilding, then it means that one drive has been replaced / re-inserted, and that the raid5 is...rebuilding
    But, through the iLO, I couldn't find anything more, like disk size, %free (on each HD and on the RAID), and the status of the HD
    I can "speak" with the ESXi using
    ssh login@IP_of_ESXi
    Then I can use df / du, but these commands do NOT show the status of a hard disk, and don't even show if a disk is removed !!
    Of course, using the local copy of the vSphere Client (directly dnloaded from the ESXi host), on a WinXP desktop, I can see
    -The datastore (RAID5), total size, and free size.
    Then through the "configuration" tab, I can see
    -The status of the HP Smart Array P410i Controller
    -The status of the lofical volume (RAID5)
    -The status of each disk, and events on them.
    I enabled the SNMP according to the following method
    # SNMP configuration
    sed -i -e 's/false/true/g' /etc/vmware/snmp.xml
    sed -i -e 's/<communities></<communities>MY_RW_Community</g' /etc/vmware/snmp.xml
    sed -i -e 's/<targets></<targets>192.168.1.250@161 MY_RW_Community</g' /etc/vmware/snmp.xml
    i.e. found the configuration file in /etc/vmware/snmp.xml (made a backup copy, just in case), changed false --> true
    So, now I have something looking like
    <config>
    <snmpSettings>
    <communities>public</communities>
    <enable>true</enable>
    <targets>
    IP_of_ZABBIX_Server@161 public
    </targets>
    </snmpSettings>
    </config>
    And then restarted the ESXi
    But I cannot access it via SNMP :-(
    So, here are the questions.
    - How can I monitor the iLO2 and the ESXi with Zabbix (1.8.5)
    - How can I turn SNMP agent ON on the iLO and on the ESXi, and I don't want to receive traps, I want to be able to poll SNMP on these system.
    Any ideas welcome
  • harmonica
    • Jan 2009
    • 251
    It may help
    • eskytthe
      • May 2011
      • 363
      And here:
      /Erik
      • gavind
        • Mar 2013
        • 59
        vg30,
        Any news if you were able to figure this out yet?
