How to monitor IO for AIX
  • jerry2049
    • Sep 2011
    • 20
    Hi~~Guys
    Who can tell me how to monitor IO for aix?
    just use command iostat?
  • pHiney
    • Sep 2011
    • 16
    aix
    are you talking about a userparam for the agent ?
    • jerry2049
      • Sep 2011
      • 20
      Yes,I means if I want to monitor Linux IO I will modify file "/etc/zabbix/zabbix_agentd.conf" and append the line below to the end:
      UserParameter=vfs.partition.read[*],/usr/bin/iostat -d -k $(/bin/df | grep "$1$" | awk '{print $$1}'|awk -F\/ '{print $$3}')|sed -n '4p'|awk '{print $$3}'
      UserParameter=vfs.partition.write[*],/usr/bin/iostat -d -k $(/bin/df | grep "$1$" | awk '{print $$1}'|awk -F\/ '{print $$3}')|sed -n '4p'|awk '{print $$4}'
      Who can help me,This script can not be used to monitor aix system
      • pHiney
        • Sep 2011
        • 16
        iostat
        try man iostat first
        you'll see there is no -k option.
        iostat's -d param takes hdiskX numbers not hdX
        as you'll be passing in the hdiskX param, there is probably no reason for the $(df ...) statement
        from there you can grep and awk as you need.
        UserParameter=vfs.partition.read[*],/usr/bin/iostat -d $1 | grep '^$1' | awk '{print $$5}'
        UserParameter=vfs.partition.write[*],/usr/bin/iostat -d $1 | grep '^$1' | awk '{print $$6}'
        p
        • pHiney
          • Sep 2011
          • 16
          Fmi
          Just as interest, what value does it have monitoring this ?
          it appears to be just an incrementing number.
          p
          • jerry2049
            • Sep 2011
            • 20
            Hi,pHiney
            Thank you very much
            Your method is very good
