Using a phone
  • nabberuk
    • May 2010
    • 82
    Using a phone
    I'm looking at setting up SMS alerts using a mobile phone (dont want to use a gateway as it depends on an internet connection)
    I understand that the phone would need to support AT commands, was looking at the Nokia 100 as it's cheap! (around £15).
    Does anyone know how to tell if this phone supports AT commands, or any other phone for that matter?
    thanks,
    Nathan
  • RohrbaGe
    • Aug 2005
    • 167
    I´m using a Siemens MC35 Terminal with serial connection.
    That works fine since 3 years, phones are not so stable like this model.
    I´m using gammu, not the zabbix internal sms.
