I,
I've been testing the new version of Zabbix 2.0.0RC1 with external scripts for AS400 (based on the nagios plugin), but without success so far.
In Zabbix 1.8.10 i use the following key in item:
check_as400_CPU.sh[{IPADDRESS} {$USER} {$PASSWORD}]
And the contents oh the script:
#!/bin/sh
classpath=`dirname $0`
result=`java -Dfile.encoding="ISO8859-1" -cp $classpath check_as400_pt -H $2 -u $3 -p $4 -v CPU -w 100 -c 100`
result=${result#*\(}
result=${result%%\%\)*}
echo $result
Parameters:
-H $2 => {IPADDRESS}
-u $3 => {$USER}
-p $4 => {$PASSWORD}
I'm following the directions in Zabbix 2.0 manual, but still did not understand the new changes.
Can anyone help fix the key?
Regards
#!/bin/sh
echo $result
Parameters:
-u $3 => {$USER}
Regards
