How to check OID recursively
  • trta
    • Jul 2010
    • 18
    I'm back with SNMP :-)
    It is possible to monitor only piece of complete OID? For example i have OID iso.3.6.1.2.1.43.18.1.1.8.1.771 which represent text value. Last digit "771" is still changing by device (which I'm inspected). With clear snmpwalk i try get value from iso.3.6.1.2.1.43.18.1.1.8.1 - without last number and whoooom - i got right values. If it has multiple last digits - I got them all. In zabbix SNMP monitoring I'm try the same, but with no success.
    Is there a way to reach my (hopefully correct) thoughts?
  • MrKen
    • Oct 2008
    • 652
    For Zabbix to work you need to get the value with snmpget not snmpwalk.
    Perhaps you could post some output from snmpget, if you get stuck.
    MrKen
    • netmon
      • Feb 2012
      • 30
      From 2.0 you can use LLD for that.
      http://www.zabbix.com/documentation/...evel_discovery
      If the "Index" is the last digit of your OID builtin LLD for SNMP would be fine.
      As the OID of your discovery rule you would specify: iso.3.6.1.2.1.43.18.1.1.8.1
      For each Device the discovery rule would build specific Items for your Prototypes.
      For example:
      Device A: iso.3.6.1.2.1.43.18.1.1.8.1.123
      Device B: iso.3.6.1.2.1.43.18.1.1.8.1.321
      Device C: iso.3.6.1.2.1.43.18.1.1.8.1.771
      If you have longer Indexes (not only the last digit of your OID) or you dont have the Index at the last position check:
      My Addons to the Zabbix Monitoring Solution. Contribute to simonkowallik/Zabbix-Addons development by creating an account on GitHub.
