Services
  • alexand3r
    • Mar 2012
    • 11
    Services
    Hey everyone !
    First of all thank you for your quick anwsers, it's really helpfull mostly when you're now a Linux or Zabbix pro ! =)
    I've got a question and I couldn't find the answer of it over the web neither on the forum.
    I'd like to monitor a Windows service on my Zabbix server. For this I've used the key : service_state[Spool (for example)]
    and the expression {xx:service_state[Spool].last(0)}>0 on my trigger.
    It's working perfectly at one exception !
    I want it to warn me only if the service is down for more than 2 minutes but I've no idea on how to manage this with this command.
    Do you know how could solve this ?
    Thank you for your time and answers !
  • MrKen
    • Oct 2008
    • 652
    Try this:
    ({xx:service_state[Spool].last(0)}>0)&({xx:service_state[Spool].nodata(120)}=1)
    Note the brackets around the 2 separate expressions.
    MrKen
    • alexand3r
      • Mar 2012
      • 11
      Thank you for your answer.
      Well I tried your solution but it doesn't seem to work, the Service still appears as "Working" even after more than 5 minutes...
      Isn't there anything that I should add on your command ?
      • MrKen
        • Oct 2008
        • 652
        Can you post your exact Trigger expression. Much easier to troubleshoot.
        MrKen
        • alexand3r
          • Mar 2012
          • 11
          Here it is :
          ({xx:service_state[Spooler].last(0)}>0)&({xx:service_state[Spooler].nodata(120)}=1)
          • harmonica
            • Jan 2009
            • 251
            Or {xx:service_state[Spooler].min(120)}#0
            • alexand3r
              • Mar 2012
              • 11
              Thank you harmonica !
              Indeed it was the right function to use I've just tried it and it worked as I wanted it to !
              Have a nice day !
