sensor[temp2] isn't supported
  • just2blue4u
    • Apr 2006
    • 347
    Hi there,
    it's me again!
    I am monitoring a fedora core 3 server with Zabbix V1.1beta8.
    It has lm_sensors installed and configured.
    sensor[temp1], sensor[temp2], sensor[temp3] aren't supported.
    My UserParameter
    UserParameter=sensor.temp1,sensors | grep CPU: | cut -c12-16
    works fine.
    Is there an explaination for this behaviour?
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
  • xaitax
    • Apr 2006
    • 39
    if u name the trigger `sensor[temp1]' it must be same in config.
    UserParameter=sensor[temp1],sensors | grep CPU: | cut -c12-16
    Or otherway:
    Trigger: sensor.temp1
    - xai
    • just2blue4u
      • Apr 2006
      • 347
      sensor[temp1] is an item which i found in standard template "host.unix". It is supported by the agentd, i think.
      sensor.temp1 is my personal UserParameter, that i defined in agentd.conf. It's a workaround for me, until i get sensor[temp1] to work.
      Question: is net-snmp required for sensor[temp1] ? Because that's not installed...
      thx,
      J2B4U
      • paultorben
        • Apr 2007
        • 10
        I was having the same issue monitoring temperature on my Gentoo box. I've installed lm_sensors and it was returning data but i couldn't see anything coming into the Zabbix Server for monitoring sensor[temp1]
        So, I tried your method, and I was getting a result from
        # zabbix_get -s 192.168.100.34 -k 'sensor.temp1'
        +46
        But still nothing came up in the server - then I remembered reading somewhere that spaces in the result would cause issues - so I made your check into :
        UserParameter=sensor.temp1,sensors | grep "M/B" | cut -c14-16
        UserParameter=sensor.temp2,sensors | grep CPU | cut -c14-16
        Which returned the "plus" sign as well. I checked the Zabbix server log and saw this in it:
        013917:20070416:114627 Type of received value [+46] is not sutable for [[email protected]] having type [0]
        013917:20070416:114627 Returning NOTSUPPORTED
        013917:20070416:114627 Type of received value [+31] is not sutable for [[email protected]] having type [0]
        So, I figured time to get rid of the plus sign.
        UserParameter=sensor.temp1,sensors | grep "M/B" | cut -c15-16
        UserParameter=sensor.temp2,sensors | grep CPU | cut -c15-16
        And finally - temperature results !
        Hope this helps someone. Also, would be nice for someone at Zabbix to put together a guide on how to get temperature working out of the box - seems like lots of folks have trouble getting this going.
        • street_style
          • Feb 2007
          Hello! I'm using Debian lenny/sid with zabbix agent 1.1.7 and latest server. But still have problems and I can't view information about temperature of M/B and CPU of machines. They are also on Debian lenny/sid. I've done all posted above but the server doesn't receive data. Sensors are working fine. Any ideas?
          • paultorben
            • Apr 2007
            • 10
            What result did you get from this - this is the easiest way to test any sensor to ses if its returning a good result:
            change the IP to the IP of the comp you want temperature data from, and 'sensor.temp1' to the full and complete name of your temperature sensor. Run this command on the main Zabbix Server ...
            Generally - when posting to a forum asking for help - provide as much detail as you can, and as much information as you can - like your 'UserParameter', the results from the 'sensor' command, etc. Help us help you.
            • street_style
              • Feb 2007
              Hello paultorben,
              Result of zabbix_get -s 192.168.100.34 -k 'sensor.temp1' is ZBX_NOTSUPPORTED. I've changed IP and sensor.temp1 to sensor[temp1] as it is at server. When I type sensor at bash there seems to be all needed information. CPU and M/B temperature are correct. I think I'm missing something at correct form of user parameter. Thank you in advanced.
              • paultorben
                • Apr 2007
                • 10
                Hi - not sure if you fixed this but the userparameter being wrong is only one option ...
                Make sure that zabbix is using the right config file and that the userparameter name (sensor.temp1) matches on both client and server
                maybe post the results from "sensor" and from running the userparameter command on the client's command line.
                also, permissions for the "sensor" command could be an issue - can you run the "sensor" command as the zabbix user (assuming you use one)?
                • RNHurt
                  • Dec 2007
                  Sensors not working on Linux 2.6.x
                  I have two updates on this problem. The first is another post in the Zabbix forums talking about the changes in the Linux kernel from 2.4 to 2.6. Basically it looks like the Zabbix sensors code is pointing at the wrong place on the filesystem to read the sensor data.
                  Also, I wanted to put in my $.02 on the workaround for this problem. My sensors command returns the temp but with extra information wrapped around the number. For example:
                  temp1:       +34°C  (high =   +79°C, hyst =   +61°C)   sensor = thermistor
                  temp2:     +24.0°C  (high =   +50°C, hyst =   +45°C)   sensor = diode
                  temp3:     +37.5°C  (high =   +50°C, hyst =   +45°C)   sensor = thermistor           (beep)
                  Notice that temp3 is "+37.5°C" and not just 37.5. Zabbix doesn't like the extra info (+ sign) so I cleaned it up with awk. Here is my UserParameter for these three readings:
                  UserParameter=sensor.temp1,sensors | grep "temp1" | awk '{ print $2+0 }'
                  UserParameter=sensor.temp2,sensors | grep "temp2" | awk '{ print $2+0 }'
                  UserParameter=sensor.temp3,sensors | grep "temp3" | awk '{ print $2+0 }'
                  This command is similar to the ones above but uses awk instead of cut. I don't know if it's the best way to do it but it seems to work.
                  Later...
                  Richard
                  • RNHurt
                    • Dec 2007
                    P.S. I've opened a ticket for this problem (ZBX-282) so hopefully we'll have a resolution at some point.
                    • ufocek
                      • Aug 2006
                      • 161
                      Hi
                      I using zabbix 1.4.4 and on ubuntu server 7.10. I put this to zabbix_agentd.conf
                      UserParameter=sensor.temp1,sensors | grep "M/B" | awk '{ print $3+0 }'
                      UserParametr=sensor.tempcpu,sensors | grep "CPU Temp:" | awk '{ print $3+0 }'
                      UserParametr=sensor.temp3,sensors | grep "temp3:" | awk '{ print $2+0 }'
                      Works only the first UserParametr sensor.temp1 but second and third it's not supported. Why? zabbix user can run shell command sensor.
                      Any ideas?
                      Albert
                      • RNHurt
                        • Dec 2007
                        Albert,
                        What is the output of the raw sensors command?
                        If I had to guess I would say that grep might be choking on the : or there is something wrong with the input. Post your full sensors output and I'll take a look.
                        Later...
                        Richard
                        • ufocek
                          • Aug 2006
                          • 161
                          Hi
                          I now what's wrong you see below I wrong write:
                          but must be not UserParametr only UserParameter
                          Now it's working everytjing
                          Albert
                          • RNHurt
                            • Dec 2007
                            Aww man, I should have seen that!
                            Glad you got it fixed. Now if we can just get native support working so we don't have to rely on this workaround.
                            Later...
                            Richard
