We are currently using zabbix 1.6.4 and I were wondering if there was a way of creating more detailed reports.
In the version we use there is a report containing the top 100 most active triggers but many of these triggers are simply just changes in state. Some of our trigger alerts are turned off at specific times of night and as a result are not needed for our report.
We would like to create a report containing the top 10, 15 or even 20 true alerting triggers, a report we could run monthly and see which of our systems have been the worst offenders. So any help with this would be great!
I'm not sure if there are any SQL commands that can be used to get this data from the Zabbix DB...??
Thanks for any help in advance
