Announcement
No announcement yet.
Host flapping up/down
  • Filter
    I have a trigger on some important host which is like that :
    {HOSTA:icmpping[,2,25,68,200].last(#1)}=0 & {HOSTA:icmpping[,2,25,68,200].last(#2)}=0
    I have set a SMS alert linked to this trigger.
    When a host is flapping UP/DOWN (mostly during spanning-tree topology change) this trigger fire up 4 or 5 times. So the problem is that we receive lot of SMS for these hosts.
    We need to have an alert when the 2 last attempt of ping failed, but once the trigger has fired up, I would like to not fire up again during a certain period.
    Do you have a solution ?
    Thank you
    You may use hysteresis to have different conditions on trigger up and down.
    Something like:
    ({TRIGGER.VALUE}=0&{HOSTA:icmpping[,2,25,68,200].max(#2)}=0)|
    ({TRIGGER.VALUE}=1&{HOSTA:icmpping[,2,25,68,200].min(#10)}=1)
    (I have replaced your two calls to last() by a single max() that does the same thing)
    It will fire as soon as you have 2 pings that fail but will not reset until 10 pings are OK.
    Hope this helps
    JBo
      Exactly what I need !
      I will check it this afternoon.
      Thank you
        I tried this trigger :
        but something is wrong:
        The host "HOSTA" is being checked every 30 seconds by a icmpping simple check. When I block (with iptables) icmp ping from zabbix server to HOSTA, the trigger fire up when 2 pings fails. ==> OK
        I keep blocking the ping, but the trigger change from state PROBLEM to OK and OK to PROBLEM every 30 seconds. ==> NOT OK
        Can I had something to this trigger to resolve this issue ?
        Thank you
          Sorry, I made a mistake on second part of the trigger.
          I have tested the formula below, it works:
          ({TRIGGER.VALUE}=0&{test:icmpping[,2,25,68,200].max(#2)}=0)
          ({TRIGGER.VALUE}=1&{test:icmpping[,2,25,68,200].count(#10,0,"eq")}>0)
          Regards,
          JBo
            Thank you JBo, I just tried and its working !
              host flapping?
                Regards,
                JBo
                I had this problem of 2 flapping internet modems caused by the VRRP router sitting between them.
                This has solved it and I can at last create reliable dependencies on them.
                Thank you, thank you, thank you!
                  What does mean?
                  Hi
                  thanks by the formula, nice.
                  Can somebody explain to us what does mean the final sentence of the trigger?
                    count(#10,0,"eq"): How many of the last 10 values were equal to 0.
                    ....}>0): If this is number is greater than 0.
                      Thanks Zaniwoop
                        Doubt
                        Hi
                        based on this thread and your experience how can we build new trigger about latency?
                        Example
                        host icmppingsec > 50 FIRE!
                        host icmppingsec < 50 OK!
                        ({TRIGGER.VALUE}=0&{test:icmppingsec[,,,,].max(#5)}>50)
                        ({TRIGGER.VALUE}=1&{test:icmppingsec[,,,,].count(#10,0,"eq")}<50)
                        I have doutbs about the last part of trigger:
                        what do you think? Can be useful??
                          Explain [,2,25,68,200]
                          please explain the following statement
                          [,2,25,68,200]
                          in
