Hi everybody!
I have 2 Clients (both Fedora Core 3, P4 3200MHz, 4x512MB RAM) with the same configuration and software.
Both are monitored using the same client, server, template.
One gives correct values for "proc_cnt[httpd]", the other doesn't even support that item!
Same with my UserParameter "sensor.tem1": its in both agentd.confs. One shows the Value, the other says "not supported".
with zabbix_agentd -p executed locally, that items are both supported and i get correct values. Only in the server GUI that mysterious behaviour is shown...
thx for help,
J2B4U
thx for help,
J2B4U
