snmp MIB
  • f.danieli
    • Apr 2008
    snmp MIB
    I’ve installed zabbix 1.8.11 from source on ubuntu and I’ve a problem with snmp item.
    If I add an snmp item with oid (for example 1.3.6.1.2.1.2.2.1.10.12) it works correctly.
    If I add the same item with oid by name (for example interfaces.ifTable.ifEntry.ifInOctets.12) it NOT works! It return this error:
    “snmp error [(noSuchName) There is no such variable name in this MIB.]”
    Can you help me?
    Br,
    fabio
  • cirrhus9.com
    • Feb 2012
    • 58
    try it with
    IF-MIB::ifInOctets.12
    Also try
    sudo apt-get install snmp-mibs-downloader
    on the Target host.
    • f.danieli
      • Apr 2008
      It works!
      I've installed
      then I've edit snmp.conf file:
      Edit /etc/snmp/snmp.conf, and comment the line 'mibs :'.
      thank you,
      fabio
      • cirrhus9.com
        • Feb 2012
        • 58
        Glad it all worked out.
