Checking system zabbix??
  • jalankaki
    • Apr 2012
    I am still a beginner on zabbix ..
    I currently assigned to be an administrator of the system zabbix. zabbix already in the system, which is currently dormant because no one care. employee who do have resigned, so at this time I requested to take care ..
    when i look at Monitoring> dashboard> status of zabbix ..
    there is a parameter = zabbix is running, but with value = No. ..
    Is this mean the system zabbix is not running ?? how to reactivate it?
    whether this is due to be automatically or there is damage to the system? how do I check whether the agents still active at this time?
    Thank for your help..
  • Zaniwoop
    • Jan 2010
    • 232
    yes, the service is not started.
    what version of Linux are you running?
    • jalankaki
      • Apr 2012
      Ubuntu server
      • Davidus
        • Dec 2010
        • 281
        sudo /etc/init.d/zabbix-server start
        than make sure that server was started
        ps -aux | grep zabbix
        • jalankaki
          • Apr 2012
          thank you..it works..
          • Davidus
            • Dec 2010
            • 281
            you are welcome
            • Zaniwoop
              • Jan 2010
              • 232
              you need to ensure that it starts automatically when Linux boots.
              Redhat (et al) use:
              chkconfig --add zabbix_server
              chkconfig zabbix_server on
              I think the Ubuntu equivalent is:
              sudo update-rc.d zabbix-server defaults
