I'm stuck at compiling Zabbix 1.8.11 properly as non-root on a CentOS 6.2.
Here is my way:
The result:
After 'make install', issuing:
I get...
It's there!
Issuing:
would solve the problem, but its not the solution.
Thank you guys in advance!
The One
Here is my way:
export LDFLAGS="-R/home/user/opt/url/lib/"
./configure --enable-server --with-mysql --with-net-snmp=/home/user/opt/bin/net-snmp-config --with-libcurl --prefix=/home/user/opt
Configuration:
Detected OS: linux-gnu
Install path: /home/user/opt
Compilation arch: linux
Compiler: gcc
Compiler flags: -g -O2 -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -fPIC -g -static-libgcc -fno-omit-frame-pointer -fno-strict-aliasing -DMY_PTHREAD_FASTMUTEX=1 -I. -I/home/user/opt/include
Enable server: yes
Server details:
With database: MySQL
WEB Monitoring via: cURL
Native Jabber: no
SNMP: net-snmp
IPMI: no
SSH: no
Linker flags: -rdynamic -R/home/user/opt/lib -L/usr/lib64 -L/home/user/opt/lib -L/home/user/opt/lib
Libraries: -lm -lresolv -lmysqlclient -lcurl -lnetsnmp -lcrypto -lm -lcrypto -lnetsnmp -lcrypto -lm -lcrypto
Enable proxy: no
Enable agent: no
LDAP support: no
IPv6 support: no
* Now run 'make install' *
* Thank you for using Zabbix! *
* <http://www.zabbix.com> *
Compiler: gcc
Enable server: yes
Server details:
Native Jabber: no
SNMP: net-snmp
IPMI: no
SSH: no
Enable proxy: no
Enable agent: no
LDAP support: no
IPv6 support: no
ldd /home/user/opt/sbin/zabbix_server
libnetsnmp.so.20 => not found
ls /home/user/opt/lib/ | grep libnetsnmp.so.20
libnetsnmp.so.20
libnetsnmp.so.20.0.1
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/opt/lib
The One
