problem with proc_cnt[httpd]
  • just2blue4u
    • Apr 2006
    • 347
    Hi everybody!
    I can't get "proc_cnt" running on v1.1beta8.
    Are there any special requirements to use this item?
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
  • mary nancy
    • Jul 2005
    • 125
    Hi
    This item is not supported in the beta versions. please use this item:
    proc.num[<name> <,user> <,state>].
    where Process name, user and state is optional.
    If name, user or state is missing all process is counted.
    Example:Number of all processes running under user "root".
    proc.num[,root].
    for further details please refer the manual.
    Regards
    Nancy
    • just2blue4u
      • Apr 2006
      • 347
      Thank you!
      It works now.
