Item for network card
  • kqfp31
    • Apr 2012
    • 48
    Hi
    I need to made an item for monitoring network card.
    I create item with key:
    "PerfCounter[NetIn,"\Network Interface(84-2B-2B-64-AB-EE)Received/sec",60]"
    84-2B-2B-64-AB-EE is MAC adres.
    I also try with name, but i have problem with the polish letters.
    All the time I have status "not supported". Any one have idea why it is not supported?
    In attachment is screan of item.
  • cirrhus9.com
    • Feb 2012
    • 58
    http://www.zabbix.com/documentation/...s/perfcounters
    Section titled "Numeric representation".
    Pages 31[56] of TheBook deals with localized languages.
    Edit: the manual link doesn't specifically tell you how (as the book does) how to accomplish this but I believe using
    Regdit > HKLM > software > Microsoft > Windows NT > CurrentVersion > Peflib > counter
    can be copied to a numeric.txt file and then the Polish equivalent of the English perf can be ascertained from numeric.txt.
    The Polish language/numerical equivalent of "Network Interface(s)" should be there.
    HTH.
