First of all, I'm fairly new to Zabbix - moving over from a different monitoring setup to it, and so far I am very pleased. This is my first post here, so if I sound like a newbie, I am
I am setting up some simple check triggers for a tcp port being open on a server. I have this working as expected, but I want to only have the trigger work if the port has not been responding for a certain number of seconds. (Doing some checks over a laggy connection that sometimes times out).
Here is what I have come up with, just an example I was playing with only:
The "Item" is set to check every 60 seconds, and I only want to be alerted if the tcp 22 has been unavailable for 300 seconds. (or I suppose I could say that I want it to alert only if it fails five checks, since 60 * 5 = 300 seconds). Either way, from my first glance at the config, this is what I came up with.
Would this be correct?
{UA OIT SSH Port 22 Only:ssh,22.last(300)}=0
Thanks!
Allen B.
Thanks!
Allen B.
