Help to start
  • p4mg
    • Apr 2012
    Help to start
    I didnt found any tread with my doubts, but it is the following: installed, configured and started the service but can't access. Is installed on a Windows 2003 server. Can someone take a look and give me a hand? Follow attached my settings.
    Thank you.
  • heaje
    • Sep 2009
    • 325
    The agent has no HTTP interface
    It looks like you are trying to hit an Agent through the web. The agent does not have a web interface. The Zabbix server piece is the only thing that communicates with the agent.
    Also, the zabbix server (which actually does the monitoring) only runs in Linux, not in windows. The web interface (which is a PHP webapp) can be installed on that same server or a separate one if wanted. It runs under your Web server of choice.
