documentation
  • lofouk
    • Feb 2006
    • 14
    documentation
    My question is very simple
    Is there a documentation which help a newbie like me to parameter (not to instal, i installed with your documentation) step by step an envirronment because i am lost
    i do not know the way to configure it. I would like to test with one machine before configurated 20 machine on linux and solaris (disk space, process, CPU, RAM ...)
    Regards
  • mary nancy
    • Jul 2005
    • 125
    Hi
    Please refer to this link for server installation
    http://www.zabbix.com/manual/v1.1/install_server.php
    and for agent installation
    http://www.zabbix.com/manual/v1.1/install_agent.php
    • grabber
      • Mar 2005
      • 85
      as far as I know there are'nt any but if you ask someone may eventually help you out....
      read the documentation on "Items" at http://www.zabbix.com/manual/v1.1/config_items.php
      could be clearer but yuo should be able to find what you are looking for or at least it will point you in the right direction.
      good luck
      • mary nancy
        • Jul 2005
        • 125
        Hi
        Please find the list of parameters which might be helpful to you:
        Percentage of disk space used by the file system / - vfs.fs.size[/,pused]
        CPU Utilization User in percentage - system.cpu.util[all,user]
        CPU Utilization Idle in percentage - system.cpu.util[all,idle]
        Free disk space / in KB(you can get in other units like MB and GB by using multipliers) - vfs.fs.size[/,free]
        Free memory - vm.memory.size[free]
        Free swap space - system.swap.size[,free]
        Host uptime - system.uptime
        Processor Load 1 Min Avg - system.cpu.load[,avg1]
        Server Availability - icmpping
        Total disk space / - vfs.fs.size[/,total]
        Total memory - vm.memory.size[total]
        Total swap space - system.swap.size[,total]
        These are the basic parameters required for availability and performance monitoring
        Regards
        Nancy
