Unsigned or float?
  • mbrijun
    • Mar 2006
    • 63
    Unsigned or float?
    I monitor a counter that returns very large integer values (ifInOctets, for example). The values are however stored as delta per second (Bytes/s for example).
    What is the "correct" way of defining this item - an unsigned or as a float? The incoming value is an interger, but a float value is stored as a delta.
