How to retrieve host and group host status?
  • chokies
    • May 2012
    • 10
    Hi, this is my first post and my first time using zabbix.. kinda stuck with how will i be able to pull the host status and hostgroup status via the api.. im kinda clueless which of the methods in the api should i use. i want to get those info being displayed on zabbix administration page to my custom php page.
    thanks
  • chokies
    • May 2012
    • 10
    i was able to figure it out.. t
    • dale
      • Oct 2011
      • 26
      since you asked, feel free to share your solution
      • chokies
        • May 2012
        • 10
        when retrieving a host using the api i had to add teh parameter select_items or select_group from there youll be able to fetch items under that host or group in which that host is under
