Monitoring DS4800
  • Alan
    • Aug 2010
    • 12
    Monitoring DS4800
    Hi guys,
    Is there a way th get performance from DS4800 San unit ?
    I didn't find anything useful on any IBM sites
    Than ks
    Alan
  • c.mammoli
    • Feb 2012
    • 48
    No way afaik, ibm DS use a proprietary protocol (by Engenio).
    You can install DS storage manager on the zabbix host and receive SNMP traps or monitor the global health status with an external check like:
    sudo /opt/IBM_DS/client/SMcli $1 -c "$2" -quick | egrep -v '(^Syntax|^Executing|^Script|^SMcli|^Performing|^$ )'
    then place an iregexp for "failure" on the resulting item.
    You can improve the script to get more data but keep in mind that SMcli is a java application, don't run it too often
    • Alan
      • Aug 2010
      • 12
      Thanks for the info
