Announcement
No announcement yet.
Creating a custom graph?
  • Filter
    Can someone point me in the right direction for creating a custom graph?
    Here's my scenario.
    I have one linux server running the SOLR indexing service. I can view the number of indexed records easily by running this command in a browser:
    http://MySolrHost:8080/solr/select?q=*%3A*&start=0&rows=0
    It returns something like this:
    <response>
    <lst name="responseHeader">
    <int name="status">0</int>
    <int name="QTime">1</int>
    <lst name="params">
    <str name="start">0</str>
    <str name="q">*:*</str>
    <str name="rows">0</str>
    </lst>
    </lst>
    <result name="response" numFound="1547" start="0"/>
    </response>
    This works nicely because I can see the value is 1547.
    To get only the value I want (without the XML output) I can run this:
    /usr/bin/curl -v "http://MySolrHost:8080/solr/select?q=*%3A*&start=0&rows=0" 2>&1| sed -n  "s/.*numFound=\"//;s/\" start=.*//p"
    So what I would like to do is have Zabbix run the above command every minute and graph the values accordingly.
    What's the best approach for this (graphing a numeric value based on a CURL command). Can someone point me in the right direction - perhaps a previous post somewhere?
    Any help is greatly appreciated!
    Mike
    You can use user parameters:
    http://www.zabbix.com/documentation/...userparameters
    You can access a graph of you item(s) (data) in the GUI ( Monitor -> Last Data)
    And you can put this graph in a screen (simple graph).
    Br
    Erik
      Thanks for your help on this.
      Can you confirm if I've done this correctly?
      Here's my zabbix_agentd.conf on my SOLR server (only the uncommented lines):
      LogFile=/tmp/zabbix_agentd.log
      EnableRemoteCommands=1
      Server=MyZabbixServer
      Hostname=MySolrHost
      UserParameter=system.run,curl -v "http://MySolrHost:8080/solr/select?q=*%3A*&start=0&rows=0" 2>&1 | sed -n  "s/.*numFound=\"//;s/\" start=.*//p"
      And then I have this as the 'key' field for the item I created:
      system.run[/usr/bin/curl -v "http://MySolrHost:8080/solr/select?q=*%3A*&start=0&rows=0" 2>&1 | sed -n  "s/.*numFound=\"//;s/\" start=.*//p"]
      I'm not sure about the key (if it should be system.run).
      I have specified the above information in my config but I'm not seeing the expected results in the graph.
      Thanks for your time.
      Mike
        More information. It says the /usr/bin/curl -v .... command "became not supported: Not supported by Zabbix Agent"
        I found this information in the log file of the server.
          I was able to correct this issue.
          The problem was that even though I was restarting the agent on the SOLR server, it wasn't actually removing the old pid in /tmp. I had to manually kill the agent using:
          killall -9 zabbix_agentd
          then restart it manually.
          After i did this, the agent reread the config file and the expected command ran.
          Thanks,
          Mike
            Yes fine - you corrected it self!
            The key can be what ever you like - just it is the same at agent side (conf file) and server side (item).
            Br
            Erik
