Backup of configuration
  • roosit
    • Apr 2006
    • 17
    Which tables need to be backed up and restore to keep your configuration. It would also be very helpfull if this could be done from the webinterface, so you can easily do a fresh install
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    All tables apart of history* and trends. You may exclude alerts and alarms as well.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
