JMX Format - Is there a master list
  • Jasper
    • May 2012
    For JMX interface, a format like this is expected as key (while configuring item):
    jmx[<object name>,<attribute name>]
    Where can i find list of object names / attribute names i can use.
    For eg this:
    jmx[java.lang:type=Memory,HeapMemoryUsage.used]
    But i want the master list, which i can refer to
  • heaje
    • Sep 2009
    • 325
    Use jconsole.exe (in the Java SDK) to connect via the JMX interface to a running Java process. In there you will be able to see all of the JMX counters that are available to monitor (plus the strings that you'd need to put into Zabbix to monitor them ).
