Hi guys! Need help for configure a trigger to Ethernet.
Need to create a trigger (on a template for Linux) for changes that occur in the input and output Ethernet.
Each server has different data. I need to know when a server is using too much bandwidth, or is sending lots of data.
For example:
My question really is, how do I create a trigger in the template to show me when there is a high peak in the bandwidth usage?
I could create trigger per server, check your values, and estimate when to trigger the alarm, but I would like to create a trigger in the template with some formula or something.
Can I use formulas in the triggers?
PD: I don't know if I explained well ... sorry for my bad bad English.
PD2: The images are from two different servers to see that they have different values.
For example:
Server A: Incoming traffic on interface eth0 May 15 2012 9:29:20 -12.55 KBps +3.39 KBps
Server B: Incoming traffic on interface eth0 15 May 2012 09:30:52 244.05 KBps +153.48 KBps
