Allo all
I was wondering if someone here is monitoring a Cisco UCS environment?
Are there templates somewhere?
Mozzi
Mozzi
<valuemap> <name>Cisco UCS Operable state</name> </valuemap>
<valuemap/>
Cisco UCS ChassisPowerOperState 0 ⇒ unknown 1 ⇒ ok 2 ⇒ failed 3 ⇒ input-failed 4 ⇒ input-degraded 5 ⇒ output-failed 6 ⇒ output-degraded 7 ⇒ redundancy-failed 8 ⇒ redundancy-degraded Cisco UCS OperState 0 ⇒ unknown 1 ⇒ operable 2 ⇒ inoperable 3 ⇒ degraded 4 ⇒ powered-off 5 ⇒ power-problem 6 ⇒ removed 7 ⇒ voltage-problem 8 ⇒ thermal-problem 9 ⇒ performance-problem 10 ⇒ accessibility-problem 11 ⇒ identity-unestablishable 12 ⇒ bios-post-timeout 13 ⇒ disabled 51 ⇒ fabric-conn-problem 52 ⇒ fabric-unsupported-conn 81 ⇒ config 82 ⇒ equipment-problem 83 ⇒ decomissioning 84 ⇒ chassis-limit-exceeded 100 ⇒ not-supported 101 ⇒ discovery 102 ⇒ discovery-failed 103 ⇒ identify 104 ⇒ post-failure 105 ⇒ upgrade-problem 106 ⇒ peer-comm-problem 107 ⇒ auto-upgrade
