How to get XML output ?
  • kollathodi
    • Apr 2006
    Hi all,
    I have zabbix up and running and am very satisfied with it. Basically I am using it to collect data using UCD SNMP mibs. But now I have a requirement. I wanna get these collected data in XML format so that I can send it for some existing(external) program which accepts XML input. Is it possible to do with zabbix ? if so, what are the steps needed. I checked the zabbix forums and googled without any success. Please help me.
    Thanx in advance,
    Nasir
  • ruckus37
    • Oct 2004
    • 57
    Try this links he did some sweet things with XML export, I never got it to work though...mabye you can.....
    • kollathodi
      • Apr 2006
      Thanx indeed for the reply. Actually I had seen the thread you forwarded. But couldn't ge it done though. Will try again now. Basically, I wanted to see whether there is any "official" way for acheiving this. I mean is it supported in zabbix itself without any sort of hacks ? . But it seems its is NOT.
      thanx again and regards,
      Nasirudheen
