How should I define the trigger?
  • blastik
    • Sep 2011
    Hi folks,
    I configured a user parameter to execute a vbs script which returns the following value to zabbix in text mode: 17/05/2012 23:56:48 .It's the date of the latest created subfolder in a folder. Let's say this trigger will check up whenever this subfolder is older than 2 days.
    Thanks!
    D.
  • ghoz
    • May 2011
    • 204
    you can't.
    On the other hand, what you could do is make your vbs return the number of seconds sincs 1/1/1970, (unix epoch), tell zabbix that this item is a unixtimestamp so it will display correctly, and then use a simple trigger using fuzzytime or now functions.
