New Item . Not Suported
  • mariag
    • Jun 2010
    Hello, i'm try create the new item for monitoring to server (as a test). then i create the item, but if i want to add on graphics, this server show the item (Not Supported). The key that use is:
    vfs.file.exist[/sdcard/archivo.csv]
    Too tried whit: net.tcp.service[ftp,10.1.7.47,21]
    whit this i want know if file exist. When see graphics show [no data]...
    I should do? I tried create the item whit type (Zabbiz Agent) and (Simple check).
    i have installed agent and server on itself host.
    I really need to read files stored on the same server and graph data. But not how
  • MrKen
    • Oct 2008
    • 652
    What you need is an 's'!
    vfs.file.exists
    MrKen
    • mariag
      • Jun 2010
      Ok, thanks.
      Thank so much, and read the file's existence.
