Help with Zabbix API
  • rich1985
    • May 2012
    I have the following php class for communicating with the api in php
    Everything works ok but instead of it returning hosts as part of its test i get
    "Retrieved maximum of five hosts: Array ( [0] => )"
    returned.
    What I would like to do is to code a page which will show a set of critical servers and services and their state without having to login to zabbix. So that users can see if there is a current issue. I've fiddled around with the api trying to get data out of different tables but all i get is the array return above.
    It pulls off the api version etc so is managing to successfully connect.
    Thanks in advance.
