Why is the trending method used different when displaying a simple graph compared to that of a custom graph with exactly the same data being displayed.
I do not like the amount of 'YELLOW' (trending) data going on in simple graphs compared to a customer graph. If i create a custom graph I can look at data from a weeks zoom level and there's no trending yellow going on and the data is easily readable and looks good. Look at exactly the same data and time period at same zoom level on a simple graph and the readability of the graph is IMHO so much worse.
Why the difference between the two graph types?
In order to get what I need do I have to create 100's of graphs manually or is there something I can do to make simple graphs act the same way as a custom graph? Or a way to automate the creation of 100's of custom graphs?
Many Thanks for any help,
Best regards,
M
Best regards,
M
