AV realtime protection enabled
  • Mutlu
    • May 2012
    Maybe somebody have did this already, questions is, how can I see info about enabled or disabled anti-virus realtime protection on machine?
    Thank you for answers.
  • jonconley
    • Jun 2010
    • 9
    Run your antivirus solution.
    Toggle the enable or disable while running regmon.
    It may or not be tied to a specific process or service but chances are that enabling/disabling the real-time protection changes a value in the registry.
    I would add a check on the registry for the value to equal enabled and also verify that the related process/service is running.
