1.1beta9
  • grabber
    • Mar 2005
    • 85
    1.1beta9
    moved to troubleshooting
    HI,
    As I was'nt getting any replies I thought i would redo this....
    Oh! btw. I am running on CentOS 4.2 x86_64
    I have installed 1.1beta9, it installed without any problems. I used batch import to install my 20 servers and set them to use the Host.Unix template. I can see data coming in and I can monitor the various Items but when I go to either view the Host Items or the Template Items I cannot see anything. This is the same for the Host.Snmp template, the other templates show show up OK. So the only problem is viewing or editing the Items via the webinterface as they do appear to be functioaning correctly.
    Any help would be appreciated.
    OK so I redid the instalation and checked "Items" before I setup any hosts and they are still invisible.
