Zabbix server is not running
  • louisxu116
    • May 2012
    the page display:
    Parameter Value Details
    Zabbix server is running No localhost:10051
    test as follows,Process of zabbix_server is exist, why is not running
    1、ps -ef | grep zabbix
    zabbix 16121 16115 0 May29 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_agentd
    zabbix 16197 1 0 May29 ? 00:00:00 /usr/local/zabbix/sbin/zabbix_server
    2、netstat -anltp | grep zabbix
    tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN 16115/zabbix_agentd
  • andreazza
    • Jul 2011
    • 16
    hi louisxu116,
    did you solve this problem?
    i'm having the same here..
    i tried to change lot of things in server.conf and agentd.conf.... but nothing happened...
    • jsantiago
      • May 2012
      • 39
      Hi louisxu116 and andreazza,
      I am also experiencing the same thing. When I checked on the process it says its has started. May I know if you happen to solve this issue? Hope to hear from you soon.
      Thank you.
      • andreazza
        • Jul 2011
        • 16
        hi jsantiago,
        yeah, i fixed it, i dont remember how, it was 2 months ago.
        i remember that i posted the solution in one topic from this forum..
        i`ll search, and if i find it, i`ll post here for you
        • jsantiago
          • May 2012
          • 39
          Big thanks andreazza.
          Hope you can find it soon. I'm also trying to search for solutions with this problem. Again, thank you.
          • mbsit
            • Sep 2012
            • 130
            Hi
            Did you correctly set SELinux?
            Disable it with command: setenforce 0 and restart the apache.
            Bests,
            Grzegorz
            Wdrożenia, usługi IT - Warszawa
            Pozdrawiam
            Grzegorz Grabowski
            ____
            WdroĊĵenia, szkolenia, umowy serwisowe
            Warszawa - Polska
            • jsantiago
              • May 2012
              • 39
              Hi mbsit,
              Thank you for the quick reply.
              I wasn't able to disable SELinux using the setenforce 0 command. I was how able to do it using the GUI function.
              Verified SELinux: sestatus: disabled
              Restarted the machine and the apache service.
              I still have the same error: Zabbix server is not running.
              Still working on my end also to solve this.
              • rugwiza
                • Jan 2013
                • 16
                zabbix not running
                did anyone able to solve this problem?
                • benbugohit
                  • Feb 2013
                  • 18
                  Yes, you have to do 3 things :
                  - verify the ip address of your restarted machine, it may obtain it with dhcp, so it may have changed
                  - modify the ip address to give the new one in zabbix.conf.php
                  - verify the ip address in agents too
