2.0, LLD and... why isn't it working?
  • WernerCD
    • Apr 2011
    • 37
    I've upgraded to Server 2.0. I've upgraded agents to 2.0. I've imported the Templates from a clean install of Server 2.0 into the upgraded Server 2.0.
    Now... I create a server "SRVWINDOWS". Attach "Template OS Windows" unto it... Windows Template has two shiny new "Discovery" templates on it.
    I'm supposed to see discovered Drives and Network Cards... and I see nothing. Rest of the items? No issue. Picking up stuff nicely I might add.
    I'm having the same issue with AIX and Linux templates. LLD is seemingly dead in the water. I'd like to get rid of all the manual drives I've added but can't really do that until the Discovery is working.
    Anything simple I might be missing?
  • WernerCD
    • Apr 2011
    • 37
    I just can't get LLD to work. 2.0 Server, 2.0 Agent, 2.0 Template Windows, Linux and AIX.
    Created a new Host, a new template and built discovery as the manual shows... nadda, nothing, goose egg, zip, zilch, zero... etc...
    What would cause Discovery to not work?
    • cferraro
      • Jun 2011
      • 16
      This is what worked for me to configure file systems with LLD
      Zabbix 2.0 makes it easy to add network devices, file systems, and SNMP devices for monitoring.  They call their new method low-level discovery and I will show you how I set it up so you can quickl…
      Hope this helps
      • WernerCD
        • Apr 2011
        • 37
        Hope this helps
        Hope this helps
        Crap... I think I figured it out.
        In the "Default" Supplied templates, where you have "NTFS|FAT32"... instead there is "@File System To search for"... it's a description of what should be looked for. Obviously a regex for that isn't going to work.
        • richlv
          • Oct 2005
          • 3112
          no, that's a global regexp - see administration -> general -> regular expressions
