Pinging from an agent
  • mbrijun
    • Mar 2006
    • 63
    Is it possible to run an "icmppingsec" from an agent? That does not mean pinging the host the agent is running on, but pinging a different host from that agent.
    I was able to configure a simple check with "icmppingsec" and also specified the <target> parameter. However I am getting ping values in the region of 2ms while it should be over 20ms. I suspect the agent is just pinging itself. The agent version is 1.6.6.
