setting up zabbix
  • andrewm659
    • Mar 2006
    • 17
    setting up zabbix
    I am new to setting this up and to mysql as well, but when i try to put the schema.sql into phpmyadmin from zabbix 1.0 it comes back and tells me that it can't create the tables. could someone please help?
  • grabber
    • Mar 2005
    • 85
    what are the exact errors that you get...is it any tables or specific tables? If you try it from the cosole what does it say? I have not used phpmyadmin so I am limited help...
