Zabbix 2.0 simple check
  • wild_li
    • May 2012
    how to use zabbix 2.0 monitor service port(use simple check)
    monitor tcp port 3389
    in zabbix 1.8,use simple check:
    key: tcp,3389
    but in zabbix 2.0 simple check only five Standard items
    icmppingloss[<ip>,<count>,<interval>,<size>,<timeout>]
    icmppingsec[<ip>,<count>,<interval>,<size>,<timeout>,<type>]
    icmpping[<ip>,<count>,<interval>,<size>,<timeout>]
    net.tcp.service.perf[service,<ip>,<port>]
    net.tcp.service[service,<ip>,<port>]
    net.tcp.service[3389] Prompt not supported.
    How to solved this problem??
  • ahowell
    • Jan 2011
    • 66
    key: tcp,3389
    net.tcp.service[tcp,,3389]
    • wild_li
      • May 2012
      ok..it's ok.
      • bellamy
        • Jun 2012
        ok.... It's ok.
