Help with Zabbix Template
  • T_Arora
    • May 2012
    Is their a Template or a way to get a Template that will show the number of times a server port has encountered a error?
    Any help will be apprishated.
  • anpat89
    • Jun 2012
    • 17
    As the port number refers to a certain application, it is possible to set a "trigger" to read out the errors from the application (port).
    For instance, for port 80, or HTTP, the trigger "Expression" is set:
    {hostname:net.tcp.service[http].last(0)}=0
    Try replacing http with the name of the service.
    To do this, go to the host that you want the port monitored on, click on the HTTP trigger, and click Clone, then enter the name of the service and hit submit.
    Hope that sorts out the problem.
    Kind Regards,
    Andrew.
