recently, a colleague of mine had the same problem going on (not zabbix-related though). Turned off the compatibility mode, still had problems. Turned out that somehow internet explorer was still advertising it as IE 6.0. even after turning off compatibility mode.
This fixed it for him:
then delete any "User Agent String" found. Next,
right-click it and select Permissions.
2. Click the "Advanced" button.
3. Un-tick the box "Inherit from parent the permission
entries..." and tick the box "Replace permissions on
all child objects..."
4. In the window with all the accounts listed, left-click
below them and drag the mouse, highlighting them all,
except "SYSTEM". Click the "Remove" button.
5. Click on the account, "SYSTEM" to highlight it then
click the "Edit..." button. Disable all except "Read".
6. Apply, OK, OK.
7. If it's not correct, enter the "User Agent String" for
your setup here:
fixing a browser so it doesn't lie is the proper solution of course...
you could also hack the zabbix frontend - just comment out the part at the bottom of js/browsers.js (beware, you will have to do that whenever you upgrade the frontend)
Fantastic, thanks for your help
As a note my IE 9 looks OK on the website above, but I still get the warning:
Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0)
My reg key is:
Mozilla/4.0 (compatible; MSIE 8.0; Win32)
