I am asked to provide a comprehensive map of our switches ports states (ie. up/down/shutdown, etc...)
Being new to zabbix, my understanding is that:
Based on the two assumptions above, it means that:
Roughly, the number of ports is 1K.
Is there a better solution if any ???
- there is no way to use specific images depending on some triggers states. It is only possible to change colors of links between map elements.
- using triggers will always raise problems, there is no way to make some trigger category to be silent.
- I have to manage as many sub-maps and hosts as I have ports to monitor
- I will be able to display ok / error states only.
- It will be a real pain to setup and manage this.
I am really sorry for that. I didn't want to tell it is not possible to change icons based on some host status (normal, disabled, problem, etc...) I was thinking about the ability to change maps icons image when some trigger evaluates to true; thus enabling display of any number of states like we can do with links.
